89GTA:Can't get my fog lamps to work.HELP!
Old Dec 7, 2000 | 08:10 PM
BigH's Avatar
My GTA fog lamps will not work. I ran a jumper wire from brown wire to purpleat the connector with switch totally removed and then both fog lamps work,HELP??
Old Dec 7, 2000 | 11:16 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Did you check the fuse? Maybe the switch is bad.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 8, 2000 | 09:37 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Check the yellow (or brown) wire at the switch. It should have 12 volts at it when the parking lights are turned on, or when the head lights are turned on with the bright lights off. If not, then check the fuse in the fuse panel, if there is a fog light fuse. If not, a fusible link is used to power the fog light relay.
You should be able to hear the fog light relay click when the parking lights are turned on & off. The relay is located either on the LH fender, under the hood, or under the dash on the LH side. If the high beams are burned out, the fog light relay will not function, as it's coil is grounded through the high beam filaments.
At the fog light relay, the brown wire should have 12 volt power to it with the parking lights on, the light green wire should have continuity to ground with the high beams off, and the light blue (or red) wire should have continuous 12 volt power to it. The yellow (or brown) wire powers the fog light switch.
Tim
1992Z28!
Nov 19, 2015 07:33 AM
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
sbrandon
Sep 9, 2015 07:31 AM
