Brights
Old Dec 11, 2000 | 05:27 PM
Bort62's Avatar
Brights
My brights stopped working, rather I imagine its the switch, What Does replaceing it Detail? and could it be related to the fact that My steering Colum Is really Worm and wiggly ?
60 Ranchero - Project ( Money Hole )
85 Z28 LG4 - Daily Driver
**Mods**
MSD Superconductors
14" Open Element
KYB all around
Old Dec 12, 2000 | 08:20 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
If your steering column is that "worn and wiggly", chances are your "brights" switch is not being engaged because the rod is real loose or not even engaged to the switch anymore. Your brights switch is located way down on your steering column under the dash, kinda' at the 11:00 position, if you're looking down the column. It's almost kinda close to the firewall. Anyways, there's a couple of screws on it that enable you to slide it back and forth to adjust it. They might be loose, as well. You'll have to get up in there to see just what your situation is. It makes it easier, also, to just drop the column (2-13mm nuts).
KAM
F-body-fan
Jan 12, 2023 01:49 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
dbrochard
Sep 25, 2015 04:56 PM
gta_knight
Sep 17, 2015 03:48 PM
louishenry
Aug 28, 2015 09:41 AM
