88 Digital dash, help !
Car: 1987 GTA
Engine: 350 TPI w/ extras !
Hey guys,
A friend of mine has just bought an 88 low mileage GTA, lovely car however the dash has gone off......well, not entirely. He thought the whole thing had gone off but if you catch it in the right light the whole dash is actually working perfectly.
However, there is no backlight. As if the dimmer is turned all the way down, and then some ! he said hes taken the dimmer module out and tested it and it is changing the voltage as it goes up and down, but it doesnt change the brightness of the dash itself ?
So basically he cant see any of his readouts at all, and wont even consider driving the car once it gets dark
Scott
Scott
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 88 Digital dash, help !
Here's a little info on the lighting.this is from the 86 Firebird Service Manual,should be the same.
Car: 1987 GTA
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Be sure to have him check the INST Fuse in the fuse-box.
There is a wiring diagram for the Digital Dash DIM circuit in this thread.
https://www.thirdgen.org/forums/inte...ital-dash.html
P.S. I never tested my alternate wiring method,...some-day I will and I will post the results when I do !!
