Need help with EST
Old Dec 9, 2000 | 09:03 PM
Ken88's Avatar
Need help with EST
What would happen with the EST undone?
I have a 88 MPFI 2.8 V6 and I just rebuilt it and it would bog on takeoff badly,but when I unplugged the EST it runs fine.I set the timming with it unplugged and with it plugged in.with it unplugged i set timmimg then plugged the EST back in and the Timming would go haywire.I set timming with plugged in and it would stay put.It would bog and hiccup and miss and all the works,I unplugged the EST and it ran perfect.
Old Dec 11, 2000 | 06:31 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Unplugging the bypass wire, or the entire 4 wire connector going to the distributor makes the module in the distributor the timing controller. Normally, after the engine is started, timing control is turned over to the ECM.
Tim
Old Dec 11, 2000 | 06:42 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
So,would it be bad to leave it disconnected?
Old Dec 13, 2000 | 07:02 AM
You would not be taking advantage of the correct spark curve, that is programed into the computer, if the computer is not allowed to control the distributor.
Tim
db057
Apr 28, 2019 07:45 AM
L98GTA87
Oct 19, 2015 10:43 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
pacoelrapido
Sep 11, 2015 02:41 PM
1992Vortec
Aug 31, 2015 08:05 PM
