Wired up fan switch, now fan pulls too much current
Old Dec 16, 2000 | 01:06 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I wired up a switch to one of my fans, but now it seems to pull a lot of current. Every once in a while if I turn the fan on while I'm at a stoplight, the current draw will actually kill the engine. Is this because I have several feet of wire going to the switch? And if I use a shorter, fatter wire, will it solve the problem?
Old Dec 16, 2000 | 08:15 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
How specifically did you wire it? It would help to know. Thanks.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://members.optushome.com/au/downunder1/rides/willie/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Dec 16, 2000 | 10:31 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I bypassed the relay. I wired the switch from the 'hot in run' wire to the fan motor wire.
Old Dec 17, 2000 | 06:23 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Get some kind of relay in there or you risk melting (and shorting out) your wiring harness.
Pete
Old Dec 18, 2000 | 12:24 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The "hot in run" wire to the fan relay cannot source the current that the fan motor requires - it is meant only to power the fan relay coil.
Tim
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
TA8487
Aug 16, 2015 12:21 PM
