How hard would it be to hook this up???
Old Dec 18, 2000 | 08:43 PM
Sweet_85_Bird's Avatar
I just found the instrument display to a 86 v6 firebird on ebay.I have an 85 and it looks nothing like that.I thought it would be better than what i have now.How hard would it be to swap.I dont have a tach or any of that stuff except speedo and fuel gauge.Heres the link:
http://cgi.ebay.com/ebaymotors/aw-cg...738774&r=0&t=0
1985 Firechicken
2.8 v6
Mods:
TB Coolant Bypass
My own kik @$$ dual intake
Freshly Painted(bright metallic blue)
Mods to come:
Either an 80 series flows or super turbo dynomax.Cant decide!
An engine is like a person,to scream it has to exhale hard -Flowmaster
Old Dec 19, 2000 | 12:58 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If the cluster is the same form factor & will physically fit in the dash, then you would have to change out the oil pressure sender & temperature sender units to gauge type senders, since the senders are idiot light type senders for the cluster you have at present. You would also have to run a wire from the coil to the cluster for the tach. You should also check to verify that the cluster pinouts are the same for '85 & '86, however, it's likely that they are the same.
Tim
69GTOby
Apr 18, 2016 02:34 PM
Breazlan
Sep 25, 2015 11:20 AM
ZMWojnar
Interior Parts Wanted
Sep 24, 2015 08:34 PM
blackbmagic
Sep 8, 2015 10:36 PM
Randomtask2
Sep 7, 2015 05:06 PM
