Can a bad alternator make system noise?
Old Dec 7, 2000 | 11:32 PM
87 Firebird's Avatar
I've got a crappy remanufactured Bosch alternator in my bird. Periodically, my sound system will emit a squealing/buzzing noise that increases in pitch with RPM's. I've managed to deduce that it is most likely the alternator, and now I'm looking into a replacement. Firstly, though, I want to know if a rebuild kit will cure my problems. I've also noticed that the bearings seem to be dry?? in the things, as it doesn't rotate too well...Thanks for the thoughts.
87 Firebird 2.8 w/!MAF/!CAT/K&N Filter/Bosch Platinum +4/Neihoff Platinum
Wires/Blue Streak Cap+Rotor/Crazy Sound System/Crazy Driver/
Old Dec 8, 2000 | 09:45 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Could be.....Or, if you have a head unit & remote amplifier, it could be a ground loop between the two units. Read the "Whine" and "grounding a amp" posts under the Car Audio board, for some additional info.
Tim
Old Dec 21, 2000 | 12:56 AM
9177's Avatar
you could also check your ignition system like plug wires and cap and rotor. all the noise i had was because of my msd box
[This message has been edited by 9177 (edited December 20, 2000).]
Old Dec 22, 2000 | 10:30 PM
Thanks for the help, 9177, but no dice. I have changed my wires, plugs, cap, rotor, battery, and I don't have a MSD box. Thanks for the help anyways, dude. But come to think of it, maybe my coil is going...good idea!
Old Dec 23, 2000 | 02:06 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
A bad diode pack in the alternator will cause noise also.
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
BrianI
Aug 9, 2015 11:52 AM
