NEW HEREE- HAVE QUESTIONS ABOUT WIRING HARNESS SWAP FOR LT1 MOTOR
Old Dec 24, 2000 | 12:19 PM
PROJECTF-BODY's Avatar
i'M PUTTING AN LT1 IN MY 91 TPI FIREBIRD. I NEED TO KNOW WHAT PARTS OF THE OLD WIRING HARNESS NEEDS TO STAY IN AND WHAT SHOULD COME OUT. WIRING DIAGTAMS WOULD BE HELPFUL.
THANKS
91 FIREBIRD RED WITH BLACK STRIPES
GTA RIMS
WS6 SUSPENSION
TRANSGO SHIFT KIT
B&M STALL CONVERTER
IGGY'S 3 INCH EXCELERATOR EXHAUST
HOOKER COMPETITION HEADERS
AUBURN POSI
3.73 GEARS
Old Dec 24, 2000 | 02:45 PM
82z's Avatar
82z
If you want to go the quick and dirty way Painless wiring offers an LT1 swap harness. I guess their kits are real slick with the wires color coded and labeled from them. if you don't want to go that way you will need the complete powertrain wiring harness. Make sure to label the wires when you disconnect them. I would recomend a factory manual for it's wiring diagrams.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Apr 6, 2009 | 04:10 AM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
Re: NEW HEREE- HAVE QUESTIONS ABOUT WIRING HARNESS SWAP FOR LT1 MOTOR
I used a factory harness. a little more time consuming, but 600 for a painless. I extended mine, just do one wire at a time. what you need to keep is dependent on how you have your ECM programed.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
