HIGH FAN SPEED
Old Dec 15, 2000 | 09:16 PM
86birdofdeath's Avatar
HIGH FAN SPEED
Some one told me that for my high fan speed to work depends on a relay under the hood somewhere. Does any one know which it is or any significant factors that can help my find it and distinquish it from all the others. I need to replace it.
Thankyou
Jason
Old Dec 18, 2000 | 12:19 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The HVAC fan relay is located near the fan motor, mounted to the air duct box. Follow the wire harness from the fan motor to the relay, if necessary.
Tim
Old Dec 29, 2000 | 09:07 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
If checking\replacing the relay doesn't do it you might look at the plug that connects to the back of the fan speed switch. I had one get hot and melt on the high speed connection and had to replace the plug.
Z's r Best
Papaginos
Sep 27, 2015 03:29 PM
bryanwood74
Sep 24, 2015 09:50 PM
armybyrd
Aug 28, 2015 03:38 PM
TA8487
Aug 16, 2015 12:21 PM
BBSDesigns
Aug 11, 2015 07:39 PM
