Manual ignition cut off switch?
Old Dec 28, 2000 | 11:05 PM
theformula's Avatar
I was thinking of installing one so I could turn it off and on at will (to prevent car theft). Like when I park in a bad area.
My question is if there is any negative effects that can be had by this? I run an MSD coil and MSD6AL. Can these units be damaged in any way by the constant on/off of the ignition system?
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Street legal with stock throttle body, runners,intake manifold,cam, and heads. Coming next..9# Procharger!
Old Dec 29, 2000 | 10:41 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
Just put a switch on one of the 12V input.
I would put it on the negative side, but i don't think it would matter.
I havent tried anything like this so this is my 2 cents.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
