Digital Dash not working properly.
Old Jan 20, 2001 | 06:30 PM
randal66's Avatar
When I start my car the dash works fine but as soon as everything starts getting warm the odometer section on my dash cuts out and automatically resets to mph, is there some sort of temp. switch in these dashes or something? Every GM dealership i talked to said they would start by getting a whole new dash cluster, but an easier fix would be much appreciated.
Old Jan 21, 2001 | 12:47 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Unfortunatly, that sounds like your only alternative. Since the odometer functions are integrated into the cluster, whatever the fault may be, is indeed in the cluster. It may be a poor solder joint or whatever, it unless you are skilled in circuit board repair, it would be very hard to locate and fix the problem. You didn't tell us if you had the T/A w/ digital dash, or a berlinetta. If you have the T/A dash, I have one for sale, at a reasonable price. Email if interested.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
tartagliaz28
Aug 15, 2015 10:59 AM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
