Coolant temp. sensor??
Old Jan 19, 2001 | 08:35 AM
Jza's Avatar
Jza
What's the deal? Is there a one for the ECM and a seperate one for the dash gauge?
Old Jan 19, 2001 | 09:16 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Yes. On my 350, the CTS (for the ECM) is on the front of the intake below the t/b, and the temp sending unit (for the dash gage) is between the #1 and #3 plugs...
KAM
Old Jan 19, 2001 | 11:55 AM
Jza's Avatar
Jza
Thanks man. I'd already gotten the answer from the archives.
All done with my rainy day project!
Old Jan 22, 2001 | 07:29 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
There's actually 4 - the cts in the front manifold for the computer, the one mentioned for the dash, one on the pass side of the block for the fans, and one in the manifold (measures air temp not coolant temp, but it's the exact same part #) and they go for about $8
89 Iroc-Z LB9 TPI auto 2.73 posi:
3" Dynomax muffler, K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, accel 300+ wires, cap&rotor, synthetic oil, flexlite transmission cooler, afpr, !air pump&diverter valve, kicker sound system, soon to attempt engine swap...
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
BWilcox
Sep 20, 2015 12:19 PM
m00n420
Sep 11, 2015 02:39 PM
FormulasOnly
Sep 10, 2015 09:07 PM
