Brake Lights Please Help!!!!!!!!
Old Jan 24, 2001 | 03:36 PM
jody92RS's Avatar
The brake lights on my 92 Camaro do not work.
I have replaced the brake light switch. All the other lights in the back work except the brake lights. The hazards also do not work at all. I believe that the ground in the back is good but could anyone explain how to check the ground on the brake light circuit.
Please Help, I do not want to get a ticket.
Any suggestions as to possible solutions would be appreciated
Jody
1992 25Th Anniversary Camaro
305 TBI
5 Speed
Old Jan 24, 2001 | 04:08 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Sounds like the Stop/Hazzard fuse.
Tim
Old Jan 24, 2001 | 04:15 PM
jody92RS's Avatar
I don't understand how the stop hazzard fuse could cause the brake lights not to work. This is the first time that I have a car that the brake lights don't work and the switch was not the culprit. Could you please explain it a little better.
Thanks so much
Jody
Old Jan 24, 2001 | 04:43 PM
jody92RS's Avatar
Thanks Tim. I looked at the fuses and saw that that particular fuse was missing. When I reinstalled the fuse, everything worked. You were a big help!
Jody
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
