VATS diagnostics
Old Jun 15, 2002 | 03:54 PM
cwalsh's Avatar
Car: 2004 Corvette
VATS diagnostics
My question is this, On my Camaro with VATS it is giving me some problems starting. Runs fine but when turned off then try to restart it will occasionally not turn over. The Security light comes on for a few seconds then goes out. Then if I wait 5 minutes it will usually restart. All though earlier today it took 20 min. Plus I was fiddling with my alarm remote hopeing that maybe I hit the buttons in some weird a** sequence that it was not letting the car start.
A quick run down of what has been done to the car: In March some one tried to steal it. Trashed the column but could not get the car thanks to the VATS!! So I rebuilt the column with a new cylinder, plus had a "Circuit City noise maker" installed. That was all in March but I am just now having these problems. What I want to know is how can I check the VATS module when this happens agian? As in which wire can I ground on the starter enable relay? And what color is it? And location?
Any help will be great!! And sorry for the long post
Chris
Old Jun 15, 2002 | 10:28 PM
92RSB4C's Avatar
If the security light is going out after 2 seconds, then it is not VATS. I could be the starter enable relay. Mine went bad and it would occasionally not start. Try replacing that and see if it helps. It is located behind the drivers side kick panel.
Old Jun 16, 2002 | 08:56 AM
cwalsh's Avatar
Car: 2004 Corvette
Thanks I will try that
Old Jun 16, 2002 | 07:25 PM
cwalsh's Avatar
Car: 2004 Corvette
Is it the 1"x3" relay? If so I can unplug it and the car will start just fine. All though the alarm is wired into the relay on 3 or so wires.
Chris
Old Jun 16, 2002 | 10:20 PM
92RSB4C's Avatar
The car will not start w/o it. You must have the wrong relay.
Old Jul 4, 2002 | 07:15 AM
bernd5179's Avatar
I think the 1*3 Relay you are mentioning is for the door locks.
Old Jul 5, 2002 | 06:03 PM
cwalsh's Avatar
Car: 2004 Corvette
I figured that one out already, but thanks. My problem ended up being my alarm. Has a starter kill feature that wen bad.
Thanks for all the insight
Chris
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
