testing open or closed loop
Old Jan 25, 2001 | 02:05 PM
marald's Avatar
Hi,
can I short the A&B term. on the ALDL connector while the engine is running on a carbed LG4 to check wheter or not I'm in open loop??? or is this only possible on fuel injected cars.
What are the effects of a torqueconverter not locking up???
Can a bad temp sensor and/or a code 32 cause a constant open loop???
Pontiac Firebird 1985
LG4 Qjet
Old Jan 25, 2001 | 02:49 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Yes, if your CTS is not functioning properly, the ecm will not know the temperature and might think the engine has not attained the proper temperature to go into "closed" loop.
Old Jan 26, 2001 | 03:53 AM
Jza's Avatar
Jza
-3 mpg, +200 rpm at cruise, tranny runs hotter thus shortening it's life expectancy (not drastically, but nevertheless)
How can you tell if it's locking up or not? With this simple test:
Find a place to cruise at about 45mph. Without taking your foot off the gas, lightly depress the gas pedal (just enough to turn on the brake lights). Your RPMs should jump about 200 - 300 RPM.
[This message has been edited by Jza (edited January 26, 2001).]
Old Jan 27, 2001 | 04:26 PM
marald's Avatar
I haven't got a RPM gauge yet (only idiot lights) so I can't try this test, is there any other way to check if TC is locking up???
GTAman
Mar 15, 2019 11:40 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
CORV3TT3
Aug 23, 2015 11:26 AM
beast94
Aug 20, 2015 06:44 AM
