Sensors and Voltages
Old Jan 31, 2001 | 09:16 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
The guages in a f-body, they get there info from a sensor, right? So my question is, how does it exactly work?? The sensor reads as a certain resistance, computer applies a voltage and reads a voltage drop, then transfers the signal to the guage. Is this somewhat how it works??
If so, what readings do the Oil pressure, Temp, Battery give off?? I would like to try and make my own program up to read all this info from the car on my laptop. (I know you can buy programs out there, but I wanna test all that stuff I learned in school)
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old Jan 31, 2001 | 01:17 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The gauges use different senders than the ECM does. The oil pressure & fuel level gauge senders are 90 ohm rheostats - (0 ohms @ minimum fuel level and minimum oil pressure), and the temperature gauge sender is a thermistor, whose resistance varies in inversely proportion to temperature. The gauges are powered by +12 volt ign power. Check out the '85 schematics on line at:
http://www.geocities.com/vtcamaro/Wire-Diagrams.html
The ECM sensors (except for the O2 sensor) use a +5VDC reference & a variable voltage output that is A to D converted for processor interpretation.
Tim
327IROC85
Sep 23, 2015 12:11 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
eustodp
Sep 20, 2015 05:09 PM
ULTM8Z
Sep 16, 2015 09:15 AM
RyanJB
Sep 2, 2015 01:27 PM
