VDO gauges acting up...very strange
Old Jan 30, 2001 | 08:45 PM
mirage2991's Avatar
ok, I got an electrical water temp and oil pressure, the back lighs are hooked up to my dimmer switch. When they are lighted, the water temp reads 30deg higher and the oil about 15 psi lower(not all the time, and it increases like the car is overheating). When you dimmer the lights or turn the healights off, it reads right. I can't figure out why the gauges lighting would effect its reading. Any ideas??
Old Jan 31, 2001 | 01:03 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You must have the ground wire for the gauges connected to the variable dash light wire. Connect the gauges ground wire to chassis ground, and connect the wire going to the other side of the back lights to the gray variable instrument lights wire.
Tim
Old Jan 31, 2001 | 06:45 PM
mirage2991's Avatar
Tim,
I have had those gauges on for the last 2 1/2 years in the car, they never ever acted up like that befor. They started doing that about 2 weeks ago, for no reason...and both of them at the same time. It would be hard to think that both gauges went "bad" at once. Never the less, my ground wires are conneceted to the frame, and the lighting is from the fuse box.
Any other idea?
Old Feb 1, 2001 | 08:37 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
If they used to work, look for a short or a broken wire.
Bubbajones_ya
Jul 6, 2024 08:32 PM
IROCtometal
Sep 20, 2015 11:08 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
