Does the computer control the gauges?
Old Feb 1, 2001 | 05:38 PM
CarNDrvr's Avatar
I have a '91 Camaro RS with the factory gauge cluster, and I want to know if it is controlled by the computer. MY CAR IS NOW CARBURATED. I know a guy that says that he has taken the computer and harness out of 3 different 3rd gens and the gauges still worked, but they were all pre '89 models. Mine has the newer gauge cluster in it, and I want to know if I can take all the computer crap out without affecting my gauges?
1991 Camaro RS, approximately 500hp 355, 11:1 compression, Eagle h-beam rods, forged steel crank, TRW lightweight 2 valve relief pistons, comp cams hydraulic roller, fully ported Dart Iron Eagle heads, Victor Jr., Holley 750, Hooker shorty headers w/3" collector, true dual 3" exhaust, Moroso spiral mufflers, T56 6-speed, Boyd Coddington 17x9, 17x11 wheels, 275/40zr17 fronts, 315/35zr17 rears, Cerillo racing seats w/ harnesses, Harwood cowl hood, 4:10 posi, Global West adjustable rear suspension and panhard bar, Hotchkis front and rear springs, 1LE sway bars, Koni shocks.
[This message has been edited by CarNDrvr (edited February 01, 2001).]
Old Feb 1, 2001 | 05:39 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
No all the computer controls on the dash is the service engine soon light.
Old Feb 4, 2001 | 11:33 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The only gauge that is controlled by the computer is the speedometer. The computer has a speed buffer built into it that the VSS supplies pulses to. The speed buffer outputs a 4000 pulse per mile signal to the speedo, and a 2000 pulse per mile signal to the cruies control module. You could leave the computer installed with the power, the VSS, and the speedo (and cruise control, if you have it) connected to it, or remove the computer completely and get a speed buffer module for a digital dash F body ('84 - '84 Berlinetta, or ?? year T/A), and use it to drive the speedo & cruise module from your existing VSS. In pre '89 F-bodies, the speed buffer was either mounted to the rear of the cluster (analog speedo), or piggy backed on the ECM (digital T/As), or mounted behind the driver's side kick panel (Berlinetta with digital dash).
Tim
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
midge54
Jan 29, 2017 07:00 PM
Ducati900ss
Sep 2, 2015 09:05 AM
justin57
Aug 20, 2015 07:05 PM
