FUEL PUMP!?!?!???!??!??!?
Old Feb 1, 2001 | 09:46 PM
Fast86TA's Avatar
hey, I need some help, I've got an 86 trans am.... it's got a 350 TPI put in it, and I THINK my fuel pump went out, it was running, and I was pulling out of my parking spot, and it just died, I have spark, and plenty of it....... I was wondering if there is a way to test the fuel pump??
Old Feb 2, 2001 | 11:43 AM
86blkbird's Avatar
Car: 1988 Formula now a T/A
Engine: LB9
When you turn your ignition key to run you should hear the fuel pump run for about 2 seconds, (make sure the ignition has been off for at least 20 seconds),and dont crank the engine while trying this it will make it harder to hear the pump running. If you dont hear the pump running check the fuel pump fuse, and the fuel pump relay. A service manual for your car will help you find the fuse, and relay.
Old Feb 4, 2001 | 11:59 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You may also check the fuel pressure at the fuel rail with a pressure gauge. It should be around 40 - 46 psig, after the ignition has been turned on, just before the engine is started.
TIm
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
