third brake light
Old Feb 2, 2001 | 04:55 PM
chevyboy07 91's Avatar
third brake light
My 3rd brake/tail light hasn't ever came on since I had the car approx 3 years. I pulled the cover off of it and checked the wiring. It looks good. I checked the fuses to see if there was a single one for it>>>>>none. What gives??? What do you guys think it could be? It's a '91 'maro and it's on the inside of the glass.
Old Feb 2, 2001 | 05:54 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I've had to deal with this a couple of times and last time it appeared to be that the contacts in the socket were not connecting to the contacts on the bulb, so I bent the socket contacts slightly inward and it worked then. You gotta be careful, cuz the socket gets real brittle and will break easy. Trust me, I know this first hand... I just got another light from someone else on this board and have to put it in still... Check to make sure you're actually getting power to that socket first, with a test light or multimeter and have someone hit the brakes for you...
KAM
Old Feb 4, 2001 | 12:14 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You may also want to check out the brake light switch. It has two separate outputs - one for the low mounted dual brake lights (light blue wire), and one for the high mount brake light (yellow wire). The orange wire is the "hot at all times" power feed to the switch.
Tim
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
