SERVICE ENGINE SOON
Old Jan 31, 2001 | 10:06 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
SERVICE ENGINE SOON
THAT SERVICE ENGINE SOON LIGHT COOMS ON AFTER ABOUT 30 MILES OF HIGHWAY DRIVING. I CHECK MY ENGINE ANDTHERE IS NO VISABLE PROBLEM. WHEN THE LIGHT COMES ON IF I TURN THE ENGINE OFF THE LIGHT GOES OFF AND DOES NOT COME BACK. THE CAR IS NOT OVERHEATING. ANY IDEAS?
Old Jan 31, 2001 | 12:06 PM
B84305-Streetmachine's Avatar
either your gas cap isnt screwed in tight enough. u need tail lamp oil a muffler bearing or
ok ok...sorry......sounds like an emission problem to me...
Old Jan 31, 2001 | 01:26 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Read the error code stored in the ECM & it will point you in the direction of the fault. Click on the "FAQ" link on the main page & scroll down to "Miscellaneous". It describes how to short the upper right two pins together to read out ECM error codes.
Tim
Old Feb 1, 2001 | 04:17 PM
Ovrclck350's Avatar
Just takin a stab at it, but my guess is you have an EGR problem my friend.
Old Feb 1, 2001 | 05:42 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
by the way, third gen cars have no clue when their gas caps are on or not!! It is not OBD II. Pull the code, doesn't sound like a big deal
1991 Firebird
350 L98 (was a 305 TBI)
T-5 transmission
Edelbrock TES and cat back
Accel manifold
NOS
subframes
jegster torque arm
MSD Digital 6
AFPR
Lakewood lcas
hurst linelock
SLP cam
relocated battery
cold air
Hypertech chip
centerforce clutch
poly bushings and mounts
etc..
14.1 @ 99mph with just headers and catback
with NOS and other mods???? twelves??
Old Feb 6, 2001 | 02:10 PM
89PFB's Avatar
i had the same problem...and my code read that the exhaust was running to lean/rich....once i fixed the exhaust leaks everyhtign ran fine
Old Feb 6, 2001 | 03:00 PM
IROCRULZ's Avatar
When I had that problem I had to replace the EGR valve.
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
