Maybe you guys can help me out with this
I'm trying to order a dual guage pod and two guages for me car. I really want the a/f ratio phantom gauge(#5755 I believe). I can't decide what I want for a second gauge though. I was thinking transmission temp ?
Also... if anyone has this setup, do the bezels of the guages show when you mount them in the pods ? Because if they do I would think black bezels would look best.
I went to carparts.com, but they dont really have a good choice of white gauges. Does anyone have a similar setup ? Thanx
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components, #24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
92 Z28 L98 350
Check out Truspeed
Car: Firebird SSA
Engine: 3.1
I have a dual pod gauges. I have the fuel pressure and transmission temp mount in them.
The bezels does show on mine. I dont have white gauges. But they match my stock gauges.
good luck on our quest
90 Firebird SSA (Bone stock 3.1)
Everything Below I've added
Engine: Accel Super Coil, 8mm Accel Ignition Wires, 170 Degree Thermostat, NKG Plautum Plugs, K&N Filter, Flowmaster 80
Suspension: Bell Tech Drop Spindles, Edelbrock PanHard Bar, Lakewood Lower Control Arms, Wonderbar IROC-Z, KYB GR2 Struts, KYB Gas-a-Just Shocks, PST Suspension Polygrapite Bushings All Round, 36mm WS6 Front Sway Bar, 24mm WS6 Rear Sway Bar
Brakes: Cross Drilled and sloted Rotors
Appearance: Trans Am Tail Lights, Trans Am Wrap Around Wing, Trans Am 16" Alum rims, Tinted Windows Rear 90% Sides 50%
Interior: GTA power seats, Overhead console, Power windows, Power locks, T-tops, Sun shade, Pioneer P77DH, Uniden radar detector, Intellitronix - Fuel pressure gauge, Transmission temp gauge. (In pods)
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can put a weld nut on the pan to screw a sensor in, or you can put a T fitting in the return line from the cooler to screw the sensor into.
Zachattack0925
Aug 12, 2015 09:52 PM
