Third Brake light
Old Feb 1, 2001 | 01:32 PM
86Chicken's Avatar
Third Brake light
The upper brake light on my 86 bird doesn't work. The bulbs are all ok, but there is no power to the assembly. I tested this with the car off, do these these light only work when driving? The lower brake/tail lights work fine. Where do I start looking for the problem?
DB
1986 FireBird
2.8L MPFI
Gutted Cat, No muffler (Sweet Sound)
Was 700-R4 --> Now T5
Headers????
Old Feb 1, 2001 | 05:52 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Its probably those goofy contact connections by the latch assm. Took me about 300 trys to adj mine to work for longer than a week.
Old Feb 4, 2001 | 11:40 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You may also want to check out the brake light switch. It has two separate outputs - one for the low mounted dual brake lights (light blue wire), and one for the high mount brake light (yellow wire). The orange wire is the "hot at all times" power feed to the switch.
Tim
Old Feb 7, 2001 | 05:46 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
are the two metal conducting shafts to the bulbs corroded? Mine were totally wasted and the dealer wants about $150 for a new unit.
Base: 89 Iroc-Z LB9 auto 2.73 posi
Exh: 3" Dynomax muffler, 3" Pipe in place of cat
Ign: GMPP 8MM wires, Accel cap&rotor, AC Plugs
Fuel: Cleaned and flow-matched injectors, afpr, !air pump&diverter valve
Sound: Clarion deck, Kicker speakers and amps
Suspension: KYB Shocks, BMR Strut Tower Brace
Misc: TB Bypass, Synthetic Oil, Flexlite Transmission cooler,
free mods, flow tech headers on the way,
engine swap and 4th gen seats in the works...
Old Feb 9, 2001 | 11:49 AM
86Chicken's Avatar
I got it fixed. The problem was that the contact plate next to the latch was 1) not connected and 2) corroded. All I had to do was hook it back up and sand the contacts.
Thanks for all your help guys!
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
