No Visible Torx Screws on my Door Panel
Old Feb 12, 2001 | 06:21 PM
GTA88's Avatar
I read the archives and saw that there are supposed to be torx head screws to be removed from the door panel to get at the power door locks. Lo and behold, after staring at my door for awhile, I cannot find ANY screws, torx or non-torx. I have an 88 GTA.
Were those archive articles for formulas perhaps, while the GTA has a different door panel setup ?
Old Feb 12, 2001 | 08:29 PM
Guest
Guest
Posts: n/a
Since I havent actually pulled one of those panels...
There are at least 3 holding the armrest on. There might be plastic covers hiding the holes. As for the plate where the inner doorhandle and doorlock are, I am not sure. Mine has a few torx screws. Look for screws somewhere holding that plate in.
Old Feb 12, 2001 | 08:49 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
The other screw is hidden behind a metal cap in the door handle area also there is another screw behind the bird.
90 Firebird SSA (Bone stock 3.1)
Everything Below I've added
Engine: Accel Super Coil, 8mm Accel Ignition Wires, 170 Degree Thermostat, NKG Plautum Plugs, K&N Filter, Flowmaster 80
Suspension: Bell Tech Drop Spindles, Edelbrock PanHard Bar, Lakewood Lower Control Arms, Wonderbar IROC-Z, KYB GR2 Struts, KYB Gas-a-Just Shocks, PST Suspension Polygrapite Bushings All Round, 36mm WS6 Front Sway Bar, 24mm WS6 Rear Sway Bar
Brakes: Cross Drilled and sloted Rotors
Appearance: Trans Am Tail Lights, Trans Am Wrap Around Wing, Trans Am 16" Alum rims, Tinted Windows Rear 90% Sides 50%
Interior: GTA power seats, Overhead console, Power windows, Power locks, T-tops, Sun shade, Pioneer P77DH, Uniden radar detector, Intellitronix - Fuel pressure gauge, Transmission temp gauge. (In pods)
Old Feb 12, 2001 | 08:50 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Opps... Thats for a 1990 sorry
Old Feb 13, 2001 | 10:33 AM
GTA88's Avatar
Thanks. Yes, there are several tabs and plates which LOOK like they might pop off with the flat blade of a screwdriver. Fingernails don't pop them off. Tried. Guess I'll have to gently try screwdriver or knife and hope for the best.
GTA
1992 Trans Am
May 10, 2023 07:19 PM
my86bird
Oct 23, 2015 12:20 PM
billybob6110
Sep 23, 2015 01:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Out-Cast
Aug 23, 2015 06:33 AM
