rear defogger
Old Jun 21, 2002 | 08:46 AM
87-5.7iroc-z's Avatar
Car: '87 IROC-Z
Engine: L98 TPI/Possible LS1 swap
rear defogger
my defogger stopped working. i think it stopped after i put on new hatch shocks. would cheap shocks cause my defogger to go out like that.
Old Jun 21, 2002 | 01:15 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Gotta make sure you hooked the wires back up, they run thru the shocks themselves.
Ed
Old Jun 21, 2002 | 02:37 PM
Car: '87 IROC-Z
I did hook all wries back up. i was thinking may the connection is lost somewhere inside the shock. they came from autozone and thier electronics and anything with wiring suck.
Old Jun 25, 2002 | 11:17 AM
irocz8292's Avatar
get a continuity tester (a voltage tester or etc. will work) Check to see if the prong on the one end of the shock is continous with the other end. If it is, then its the wiring somehwere. check to see if it is getting power out of the wire that goes to the shock of the driver side. The wire on the passenger side goes to a ground.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
