windshield wipers
Old Feb 9, 2001 | 04:01 PM
MrF-body's Avatar
windshield wipers
the car has delay wipers. recently they started pulling this crap where they won't turn off. if you turn them to off they just keep on going. if you switch them to "hi" they stop wherever they are. any ideas? i'm thinking it's the switch. i just want some more feedback, on problems you guys have had. thanks for the help!
have a beat to hell 87 GTA 305ci 700r4
t-tops,recaro,honeycomb wheels,digital dash
paid $600 at a junkyard for it (i had to save it)
Old Feb 12, 2001 | 12:39 PM
89RSProject's Avatar
My RS does the same thing, except mine don't stop. So talk about a PITA, I have to disconnect the wire from the relay under the hood. The mech where I bought it from says its the switch. I just haven't had them fix it because he claims it will take two hours. I think he doesn't know what hes talking about, he says he has to take out the column???? I would say it is the switch to make a long story short.
Old Feb 12, 2001 | 01:32 PM
MrF-body's Avatar
yeah, i looked at the switch. it is a pita. looks like half the column has to come apart.sigh
Old Feb 13, 2001 | 11:00 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I just put in intermittant wipers. To get to the switch, you need to pull the steering wheel, remove the lock plate, remove the turn signal switch, remove the ignition switch, then remove the plastic shroud. There is enough room to snake the wire from the switch down the lower part of the column. Took me maybe an hour after i bought the right tool (you need a special tool to remove the lock plate).
It might not be the switch. The electronics for the intermittant wipers is under the black cover thats on the wiper motor itself.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
codeysabatini
Nov 10, 2015 04:07 PM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
