rear hatch motor stopped working...
Old Feb 5, 2001 | 07:29 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
My lighter body has a short in it that makes the acc fuse go pop so I have unhooked the lighter connector. Today I tried to swap in another lighter body but either it also has a short or the short is somewhere else b/c the acc fuse popped again. So I disconnected the lighter and replaced the fuse. Now my hatch motor won't pull the hatch down or operate at all as far as I can tell. The lid fuse and all other fuses are ok. I know there's a big piggyback connector (S219) where the orange lighter wire and hatch wire would have a connection but all the other stuff that runs through that connector works fine. Anyone have any ideas? could I have fried the motor? Thanks very much in advance.
Base: 89 Iroc-Z LB9 auto 2.73 posi
Exh: 3" Dynomax muffler, 3" Pipe in place of cat
Ign: GMPP 8MM wires, Accel cap&rotor, AC Plugs
Fuel: Cleaned and flow-matched injectors, afpr, !air pump&diverter valve
Sound: Clarion deck, Kicker speakers and amps
Suspension: KYB Shocks, BMR Strut Tower Brace
Misc: TB Bypass, Synthetic Oil, Flexlite Transmission cooler,
free mods, flow tech headers on the way,
engine swap and 4th gen seats in the works...
Old Feb 6, 2001 | 05:01 AM
Omar's Avatar
Check the wires at the motor with a test lamp or meter and make sure you are getting power back there, then post back.
1989 IROC-Z 5.7L
Old Feb 6, 2001 | 12:29 PM
KS91Z28's Avatar
There is a switch on the pull-down assembly that tells the motor to go up or pull down. Try flipping the switch in the opposite direction. For the lack of a better description, sometimes the motor gets confused when you blow a fuse or something.
Old Feb 14, 2001 | 09:32 AM
GTA88's Avatar
My accy fuse blows a lot too, so I disconnected my lighter. But even when the accy fuseis blown, my rear hatch motor still works ! If anyone knows why, let me know.
88 GTA
1992 Trans Am
May 10, 2023 07:19 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
