wiring cooling fan....
Old Feb 14, 2001 | 06:12 PM
AirN1's Avatar
is it wise to wire the cooling fan to run constant while the engine is running or hook it up to a toggle switch? and how would i go about doing it?
Old Feb 14, 2001 | 06:33 PM
The ODB's Avatar
Don't run the power from the toggle to the fan, it will melt the toggle. You must use a high amp relay and run battery power to the relay to power the fan.
Get a thermostat switch from autozone to trigger the relay. They are only $16 , and you can use a toggle as an override to turn on the relay/fan when you want.
ODB
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
TheExaminer
Aug 26, 2015 04:59 PM
Bryan F
Aug 18, 2015 02:28 PM
Leggman1
Aug 6, 2015 04:15 AM
