Computer ign. timing control
Old Feb 16, 2001 | 05:22 PM
TK87TA's Avatar
i was wondering, if i replaced the non_functioning computer carb with a non_comp. controlled carb, will the timing still advance? i'm used to the SES light staring me in the face ( no knock sensor, speedo disconnected, no correctly working BARO sensor...etc) i am buying a vacuum adv. distributor for the 355, but i'm short on cash, and sick of 2 barrels.
1987 Trans Am
"Tired, old 305"
4 barrel, 3.42 rear
700R4 + B&M stage 2 Transpack
Chevy Orange 1980 350 Small Block sitting on the stand waitin' for heads.....
Best 1/4 mile time:
16.075 @ 85.52 MPH
Old Feb 16, 2001 | 05:35 PM
84TransAm's Avatar
Timing will not advance due to the computer, if that's what you are asking. Ignition advance on a CC vehicle [computer controlled] is hooked up through the carburetor, which is where all the variables are collected. The computer adjusts for certain preset variables to give the car its current timing. My advice, is if you can swap out for non-CC, it'll give you more control over the car, and better performance.
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
Old Feb 18, 2001 | 11:42 AM
The ODB's Avatar
You NEED a non-CC distributor.
In the mean time you can get by with jumping two of the leads in the plug that would normally plug to your TPS. This will make the computer think you are at WOT all the time and it will give you full advance.
did you car also come with a MAP?
nevermind I see you call it a baro-sensor. If you hook up a good MAP the computer may operate the distributor normally until you can get a replacement.
ODB
[This message has been edited by The ODB (edited February 18, 2001).]
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
midge54
Jan 29, 2017 07:00 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirim
Aug 9, 2015 06:19 PM
