accel DFI
Old Feb 19, 2001 | 11:42 PM
gtaguy's Avatar
accel DFI
I have a 1987 trans am GTA that is heavily modified. I just put a 383 in it. It has a paxton blower on it which I removed and a D1-SC will take over. I have it decently tuned but I know there is a lot more potential. I think that DFI may be the best way to go. I have heard that a new better version has come out. I am familiar with what I can do with the setup but not how it installs. Do i have to re-wire the car, or does it just plug in? I run a MAF system will this need to be changed to speed density? If so, does it come with the required parts to convert? I have looked through the accel catalog and I must be missing something because i don't see a part number for what I am looking for. If anyone has the part number it would be greatly appreciated. I am going to try and call accel during the week. Is there anything else that I will need once I get the setup? Is it easy to tune or do I need to take it somewhere? My tuning ability is average.
Thanks!
-Matt
Old Feb 20, 2001 | 12:46 AM
FastBroker's Avatar
Call Rich at CruzinPerformance.com. He's a DFI master and has good prices.
Old Feb 20, 2001 | 07:06 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Matt,
It sounds like you're taking the same path I've taken -- Paxton to ATI.
I noticed how you're in California. I just found out that the Accel DFI has NO emissions provisions. It is a stand alone system that completely eliminates your present engine wiring including emissions, be it MAF or SD. This has completely ruled out the DFI in my opinion; I have a yearly visual and tailpipe emissions check here in Arizona.
Because my MAF maxes out, it registers 255 g/s at only 3,000 rpm, I feel a lot of potential is lost above this point. So I'm seriously considering converting to SD (730 ECM) and Carroll's Superfueler system (a supplemental electronic fuel injection system that operates in boost only).
In the process of talking to Glenn91GTA (moderator of the EPROM board), he mentioned going to the 749 ECM. This ECM is used on GMC Syclones and Typhoons (these trucks have factory turbos). The difference between this ECM and Turbo T/A's is the fact that it is speed density and uses a 2-bar MAP sensor (reads boost!!). We do not know of anyone who has tried this conversion yet and are currently researching the viability of using the 749 and it looks very promising. Using the 749 would eliminate the need for the Superfueler.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Paxton (6-psig): 12.57 @ 111 mph.
Paxton (6-psig) & 50-hp nitrous: 12.04 @ 114 mph.
ATI D1SC (10-psig): ?
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Feb 20, 2001 | 03:43 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
If you do decide to go with the DFI, take a look at this website http://www.whiteracing.com
They sell a complete set up for a reasonable price. They build a jumper board to go from your existing wiring harness to the Accel/DFI ecu. They also have the speed density conversion kit (which you do have to do for the DFI).
I bought a complete package from them which included the Accel ecu, Calmap, the jumper board and speed density conversion kit for a very good price. It has also worked flawlessly for a few years now.
Fanatic1074
Oct 3, 2022 05:57 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
efiguy
Sep 27, 2015 01:30 PM
e3pres
Sep 9, 2015 01:51 PM
