CODE 23..HELP!!!
Old Feb 19, 2001 | 08:34 AM
SERVCAL's Avatar
CODE 23..HELP!!!
I have an '86 with a 2.8l and I've been getting code 23. My manual says it's the VSS, but mechanics are saying my car doesn't have one(no cruise control). Can anyone help me figure out what's going on here and let me know how to resolve the problem?
Old Feb 19, 2001 | 10:35 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Your car does have a VSS and a VSS buffer on the rear of the cluster (analog speedo), or a VSS mounted in the transmission with the VSS buffer near the ECM (digital speedo T/A), or behind the driver's side kick panel (Berlinetta). The VSS buffer supplies the ECM with a 4000 pulse per mile signal.
Tim
Old Feb 19, 2001 | 10:45 AM
SERVCAL's Avatar
But is it likely that the buffer is defective or could there be another problem? Where can I get the VSS buffer short of going to the dealer? thanks.
Old Feb 20, 2001 | 04:51 PM
If you have an analog speedometer, and it is functioning, then the problem is either the speed buffer in the cluster, or its connection to the ECM. Pull the cluster & inspect the optical pickup & reflective disk in the speedo & the connections to the speed buffer module mounted on the back of the cluster. Also, make sure there is continuity between the ECM & the cluster plug on the VSS wire.
Tim
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
