Electrical wiz needed
Old Feb 21, 2001 | 06:15 PM
XxMoLexX's Avatar
Ok i put in aftermarket headlights. I was runnin the wires and i saw that there was an opening in my fuse box that said fogs.
What do i have to do to wire them into that spot?.. I saw a Real bright Red wire and a light blue wire which seemed to be going into the fuse spot for the fogs. I was wondering how to do this so that i can eliminate the wires goin to the battery. Will this happen if i do this?.. i can get a pic of the wiring diagram for the lights if it would help. Its a standard setup with a switch that has a light on it.
Im sure u guys on here might see this as a piece o cake, but i dont wanna fry the car
91 3.1 RS.
T-Tops
12" tube in the trunk
16" ROH Rims (Need Center Caps) ROH Rims
Firehawks all Around
New BOSCH plugs and wires.
Old Feb 21, 2001 | 07:38 PM
The ODB's Avatar
DO NOT power lights from anything on your fusebox.
They need to be powered directly by a link to the battery via a high-amp relay.
ODB
IROCZ1989
Jan 24, 2016 03:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
