Does the alt. wiring need to be upgraded with a CS144?
Old Jun 25, 2002 | 11:03 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
I installed a CS 144 alternator from a caddy a few days ago. I used an old article from Chevy Hi Perf. to help. I added a resistor like they suggested. They also said to upgrade the wire that goes to the "bat" post on the back of the alternator to 8 guage. How much wire do I need to change to 8 guage? Down, to the starter then where and how far?
TIA
Old Jun 26, 2002 | 03:35 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Just the wire from the back stud to wherever it goes. The other two wires stay the same. ARemember also that with that alt you will see LESS charge at idle. Just so you don't think you have a problem. The common tie point is the starter I think. Only to that point, the battery wire will carry back to the batt and is more than heavy enough.
Jake_92RS
Jan 28, 2020 10:37 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
gta90
Sep 15, 2015 04:00 PM
jbd1969
Aug 17, 2015 07:06 PM
Fronzizzle
Aug 17, 2015 02:52 PM
