Painless wiring harness. R they really painless & worth the $
Old Feb 23, 2001 | 10:06 PM
vortech305's Avatar
I have a 88 305 TPI and im considering getting a complete engine wire harness for it. I ve heard alot of complaints about them have any of u guys had any experiences with them, if not do any of u know a site or phone number of a place that sells engine harnesses for mass air flow. I know summit or jeggs sells painless. Is there another aftermarket engine harness around.
92' camaro
New 305 block TPI conversion, Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system.
Soon to come!!!
Procharger system 12lbs o boost.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Feb 24, 2001 | 09:05 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I have the 60103 on my car, and I get alot of questions about it, and here is what I tell everybody. (due to the amount of questions, its easier to copy and past the origianal, then retype over and over!)
Jay, Painless isn't lying to you when they say they have all the factory
hookups, they indeed do. What they don't tell you, is that its for "custom"
applications requiring you to run the wiring harness through the firewall
right near the motor. I tried to use it as a "factory replacement" and ran
it through the original "passthrough" behind the passenger side fender.
This caused my wiring harness to be 2.5 feet to short. Threre is a "point"
in the wiring harness where the distriubter wires break out, and the two
banks for the injectors and other sensors for the Throttle body area. This
MUST be behind the distributer for it to hook up properly. Unfortunatly for
me, running it through the passthrough caused this "point" in the harness to
be in front of my blower motor. I had to cut the entire harness in half,
and solder in 2.5 feet of EVERY SINGLE wire, to move this "point" where it
needs to be.
Painless also hooks the fuses up differently. It uses a single fuse for the
ENTIRE harness. Instead of the factory 2 fuses for the injector banks, one
for the ECM, etc... You have just one. So if you ever develop a short and
blow the fuse, you will have the ENTIRE wiring harness to inspect to locate
the short, instead of just the effected circuit if it was a factory harness.
Painless also has you mount the fuel pump relay, EST bypass connector, MAP
sensor and Fuse under the passenger side dash. First of all, it makes it
very inconvenient to set timing. It also makes you have to run like a 3
foot vacuum line to the MAP sensor, which may scew readings. Instead, I ran
three wires from where painless wanted you to mount the MAP sensor, all the
way up to the firewall, and now my MAP sensor only uses an 8 inch vacuum
line.
If I had to do it all again, I would find a used factory harness. I hope
this helps.
BT
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors, Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Feb 24, 2001 | 09:38 AM
vortech305's Avatar
Yeah it sort of helps. I have the original harness and it dosent look that good of shape. And im guessing i could buy a factory harness from a junked car. Problem is alot of people will not part the harness mainly cause its part of the motor when they sell just the motor. Do u think GM still sell the factory harness.
92' camaro
Soon to come!!!
Other car;
Old Feb 24, 2001 | 08:48 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
GM probably doesn't have the harness available, and if they did, it would be big bucks. Many places will sell the harness seperatly, like thirdgenparts.com. You can also run searches on ebay, I see alot of harnesses there.
I hear there are some aftermarket wiring harnesses that are identical to the factory harness, but I don't recall who makes them, I'm sure somebody will step in and help.
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Old Feb 24, 2001 | 10:38 PM
bigvic's Avatar
I dont know if this helps or not, but gm still sells a harness for speed density tpi under pn 12080890. I know yours is maf, but surly they still sell the mafs also. As far as the price is concerned Mauro Giambruno's tech article on this site "How To Convert your 1990-92 Camaro TBI To Speed Density TPI", states that Dal Lambert (Im guessing he's referring to Dal Slabaugh at Lambert Buick, Pontiac, and GMC in Ackron, Ohio?) sells the harness for $241. Sounds like a good price to me for OEM. Like I said, I know this is a speed density harness and yours is maf, but surly the price difference between the two is not much, if they still offer the maf harness.
Anyways, I hope this helps and makes since. Its really late and I feel like Im rambling. Good luck!
Old Feb 26, 2001 | 01:18 PM
vortech305's Avatar
hey big vic down here in ny i asked the GM dealer for the engine harness for an 88' 305 TPI PRICE $842.00 Not bad i say, yeah right what is GM on crack how could it be so damn much. By the way to the guy who wrote a website to www.fuelinjectionspecialties.com there is no such website if possible do u have their phone #. thanks.
92' camaro
Soon to come!!!
Other car;
midge54
Dec 27, 2019 04:14 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 21, 2015 01:54 AM
squiggy2
Aug 9, 2015 09:30 PM
