Power locks having problems...
Old Jun 27, 2002 | 10:44 AM
yOp 84 Recaro's Avatar
Hi..
I have to hit the lock or unlock button about three to four times for the door to actually lock or unlock.. its weird.. it works just not all on one touch.. Im not sure if this is electrical or not.. so I appologize if this is in the wrong section...
Old Jun 27, 2002 | 11:26 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
do a search on power locks...I've read that taking your door panels off and spraying the c*ap out of the lock assemblies with a good lubricant will make a big difference. I would also check the contacts at the switch for corrosion.
Old Jun 27, 2002 | 12:03 PM
86IROCZ's Avatar
Search?!??! What's a search?? You mean it's a way to do some research on a topic that's been discussed before? Wow, what an age we live in!
Old Jun 27, 2002 | 01:45 PM
I ran a search.. in a bit of a hurry.. could full well have missed something.. thanks for your help
Old Jun 27, 2002 | 02:04 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
Sarcasm lives!!!
Old Jun 27, 2002 | 04:25 PM
MdFormula350's Avatar
Just take you panel off and spray all the moving parts for the door lock mechanism with a good silicon. that should help, if it does not use a good power lock switch so u can rule out the switch, and then i would change the power lock motor thingy inside the door all the way at the end under the key hole.
BRoss99
Aug 10, 2025 05:08 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mantaguy
Sep 1, 2015 08:39 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
