Best MSD combo to go with MSD6A?
Old Feb 28, 2001 | 02:32 PM
HybridZ's Avatar
Car: 13' ZL1/91' Z28/10' Audi A5
Engine: 6.2L SC/5.7L 350/2.0L Turbo Quattro
Transmission: M6/700R4
I'm currently running a MSD 6A. Anyone out there knows what the best MSD cap, rotor, wires, and plugs to go with 91 Z 350ci? Part numbers too if you've got them. There are just too many applications and part numbers to know what works the best with my car. Thanks in advance.
SS 17x9.5 wheels,
k&n filters,
MSD 6A,
Accel 8.5mm Wires,
Accel Cap & Rotor,
SLP intake runner (plennum not ported yet, soon)
High flow cats,
SPOHN panhard bar, lower control arms, and subframe connectors,
Baer front track system,
3" Flowmaster Exhaust System,
2100 Stall High Performance Torque Converter,
300 watt sound system,
and soon to come...ZZ4 crate motor...hopefully.
Old Feb 28, 2001 | 02:56 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The Blaster HVC coil (8252) was designed to work with the MSD-6 ignition systems (according to their tech dept). Go to www.msdigniton.com & check it out. Also, the MSD resistor plug wires have a very low ohm per foot rating (around 50) & should be used to minimize loss from resistive power dissipation. I have found that the Jacobs cap & rotor are are good quality, as far as rigidy - compared to GM & Hypertech. As far as plugs, I have used Accel non resistor plugs with an MSD setup, to minimize power dissipation.
Tim
Old Mar 2, 2001 | 03:55 AM
Jza's Avatar
Jza
I use the MSD Blaster remote HEI coil (8226), MSD cap (8426), and MSD rotor (8410) with my MSD 6AL (6420), through Taylor Spiro Pro wires (74211) seperated with Moroso seperators (72161), across Accel resistor plugs (8179).
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
