Do i have a rev limiter in my 87 gta
Old Mar 3, 2001 | 01:59 PM
Stormshadow GTA's Avatar
like the subject says do i have one
Old Mar 3, 2001 | 03:10 PM
Blade's Avatar
Nope
92 Z28 5.7
Ported stock heads, XR270HR-10 cam, TES headers
Crane AFPR, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
Old Mar 3, 2001 | 03:39 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Technically, yes you do. The ECM will shut off the engine at approximatly 10031 RPMs. Will you ever see this before shooting a pushrod through the valve cover or sending a rod through the block? Probably not, but its what the PROM is set at.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Mar 4, 2001 | 10:14 AM
Blade's Avatar
The reason I said no, is because I'm not too sure that feature works in the ECM, GMTech. I reset the setting to 4000 RPM just to see it it works, and the engine revved happily up to 5500. So I don't really think it's functional. Hehe
92 Z28 5.7
Check out Truspeed
Old Mar 4, 2001 | 12:19 PM
Vader's Avatar
Storm,
And just to muddy the waters a bit more, you also have a speed limiter. This is a required parameter in the ECM programming, and where "limited" cars had this number set at 118 MPH, the "unlimited" cars had this set at 255 - the maximum value that could be programmed into that parameter. If you get to the point where that becomes a problem, let me know, since I'd like to know what you've done to get that much power.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Old Mar 4, 2001 | 06:11 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Blade, I have been wanting to try that myself, and the only reason I would see that it wouldn't work, is if you didn't set the resume speed low enough? I don't know. I know everything else I have done works flawlessly, like my cooling fans on at 190* and off at 180*, etc...
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
gta892000
Aug 11, 2019 11:16 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
