Fuse shorting out for tail lamps / instrmnt panel / head lamp motors??
Old Jun 28, 2002 | 11:47 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
This is in my TTA, the fuse thats for the head lamp motors that lower them and the tail lights, and the interior instrument lights keeps blowing fuses.
When installing a new fuse with everything off, as soon as contact is made it sparks and blows it.
How can I begin to trace the cause down, or may it be as simple as a relay, maybe for the head light motors??
This car only has 11k miles and the wiring has not been touched, the brake lights and head lights still work fine.
Never had an electrical short before in any car, this is my first.
Old Jun 29, 2002 | 10:28 AM
dale davidson's Avatar
preliminarly, u can do a visual check of the wires, u most likely wont see anything so then i would suggest getting a hold of a multimeter and start checking to see if there are power wires grounding out on the chassis, the meter will help u identify which wire it is exactly. in the mean time during you visuall, try to find wires that are crimped, squeezed or anything like that. good luck.
Old Jun 30, 2002 | 11:14 AM
2QUIK6's Avatar
I found the problem to be the head light motor relay thats on the driver side firewall, its got 5 wires on 1 connector and 4 on the other. Just unplugged both connectors and the inserted a fuse and it didn't blow, lights all worked.
Plugged the wires back in the relay and the headlights lowered and everything works for now. Maybe just had a bad connection of the relay needed a little tap, but at least I know the source of the problem.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Aug 14, 2015 08:25 PM
