More Digital Dash Problems!
Old Mar 5, 2001 | 03:51 PM
8GTA8's Avatar
The digital dash on my '88 GTA is causing me stress. When I flip on the headlights or parklights, all of the instrumentation goes blank on me. When I switch off the lights, everything comes back. Also, I noticed that controlling the dimmer switch causes everything to go berserk, everything displays fine when the dimmer is at the dimmest position, if I move it up a bit, everything goes haywire. Anybody experience the same problem? Anybody have any helpful suggestions to rememedy this? Any help would be really appreciated. Thanks
Old Mar 6, 2001 | 12:13 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The dimmer control is a variable resistor (potentiometer), and is either defective, or needs cleaning. To clean the control, get some tuner or contact cleaner from an electronics parts store & spray the dimmer control while turning the control back & forth. Be careful not to get the cleaner on any plastic parts, as it will discolor them. If that does not work, then bypassing the dimmer control (probably by shorting the two dimmer control wires together) will work, as well.
Tim
Old Mar 6, 2001 | 12:26 PM
8GTA8's Avatar
Thanks Tim, I'll give your suggestions a try.
Old Mar 7, 2001 | 02:25 PM
Brent's Avatar
If you need the factory schematics and trouble shooting guide they are availible here: www.paonline.com/wildkat/digidash/
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
