Innacurate Fuel Tank Readings
Old Mar 7, 2001 | 02:41 PM
8GTA8's Avatar
I'm experiencing problems with my fuel guage in my '88 GTA. It has a digital dash. The guage will not show true fuel level. If I fill it up, only one-quarter registers on the guage. I've gone so far as to remove the tank and check the sending unit, it works fine as it shows the correct resistance (90 ohms full, 0 ohms empty), Also, checked all my grounds etc... I've got so frustrated, I decided to add an auto meter fuel guage, I used the exact same factory wires from the sending unit, now it reads properly. However, I don't like the "aftermarket look" and I want my guage to work again. Any suggestions? The ECM was removed from the car when I bought it (I'm running a carb for now), would this have any effect on my factory guage?
Old Mar 7, 2001 | 04:46 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
It's probably the gauge, itself. Pull the cluster & apply power & ground to the gauges circuit. The gauge should read full scale with the gauge input open & should read low scale when the gauge input is grounded. I'm not sure if GM sells the individual gauges for a cluster - probably not - but you should be able to pick up a used cluster from a junk yard for $75 to $150 & swap the gauges.
Tim
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
