locks & hatch switch wont work after swap
Old Mar 7, 2001 | 11:31 PM
zee28's Avatar
Car: 86 iroc
I just put a 92 interior in my 86 iroc now my hatch switch wont work or the door locks.The weird thing is I havnt even switched the door panels or touched the locks yet.I did have to unplug the window and hatch switch in the console,but the windows work now.I thought maybe I hooked the wire to the e-brake light in console to the hatch switch for a second,could that have caused this,or did something maybe just get unplugged?Would the hatch have anything to do with the locks?
~mike~86 IROC-Z
Old Mar 8, 2001 | 10:10 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
On my '92, if I blow the fuse for the door locks, my hatch switch doesn't work either so check your fuse.
1992 Camaro Z28; Engine:383 w/Edelbrock RPM ported heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, 1.5 Roller rockers, 30 lb injectors. Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, 4.10. Super Ram.
Double-Pump This! EFI Rules!
Definition:
NOPI: n. 1. import 2. Sticker worth 47 hp 3. import with 6" exhaust tip
antonym: smallblock
Old Mar 8, 2001 | 11:36 AM
zee28's Avatar
Car: 86 iroc
thanks,I will check it.then i have to find out what blew it,right?
~mike~86 IROC-Z
Old Mar 8, 2001 | 01:53 PM
Engine: 406
Yep, my cigarette lighter was bad and would blow the fuse if I stuck it in. No locks, dome light, or hatch release. Good luck.
Definition:
antonym: smallblock
Old Mar 8, 2001 | 04:03 PM
zee28's Avatar
Car: 86 iroc
yeh it was the fuse.I looked at it one time and couldnt tell.Anyway i think when i hooked the wrong wire to it(hatch switch)it blew.what do u think.
~mike~86 IROC-Z
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Fronzizzle
Aug 9, 2015 01:15 PM
