Gauges...
Old Mar 8, 2001 | 10:39 AM
87IROCZ28's Avatar
Gauges...
Can Anyone tell me if it is possible to replace all of the stock gauges in an 87 Iroc with aftermarket gauges from Autometer? and by that i mean, just take out the old ones and swap in the new ones, with VERY minor wiring changes.... THANKS MUCH!!!!
Old Mar 8, 2001 | 11:38 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No
Old Mar 8, 2001 | 12:05 PM
87IROCZ28's Avatar
Okay, do you have an idea as to what is involved then? Thanks...
Old Mar 9, 2001 | 03:35 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
In addition to replacing the gauges, you'd also have to replace all the senders. In some cases you might be able to butcher the factory harnesses to use some of the wiring, but it'd probably be easier to run new wiring. There's also the matter of fabricating a new instrument panel to hold the new gauges.
Old Mar 9, 2001 | 08:34 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I just finished swapping out all the stock gauges for Autometer gauges. Its a time consuming project but its not too bad. The biggest hassle for me was fabricating the panel to hold the gauges. I think it was worth the effort though, it looks nice and you don't see too many other cars with aftermarket guages in the dash. Email me if you have any questions at jbenge@hotmail.com
I'll try to post a pic, not sure if it will work since its at geocities.
best 1/4 mile so far: 13.4 @ 101mph
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
Old Mar 9, 2001 | 01:14 PM
87IROCZ28's Avatar
WOW, it looks damn good!!! Thanks so much!!!
Van Nuys born
Apr 9, 2014 06:43 PM
craftsmandan
Sep 17, 2013 08:39 PM
KiLLJ0Y
Mar 11, 2013 02:46 PM
5.7chevykid
May 3, 2012 01:08 AM
