Autometer A/F gauge is acting very funny
Old Mar 10, 2001 | 01:59 PM
theformula's Avatar
My autometer gauge acts funny. It fluctuates back and forth. With my blower connected and without it. It is connected directly to the 02 sensor wire. I think that is fine, because the Edelbrock and K&N air fuel ratio gauges are connected directly to an 02 also. Am I correct?
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5200rpm limit),Holley 9mm wires,Ac delco R43ts plugs,stock chip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Mar 11, 2001 | 10:32 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
In closed loop mode, the O2 gauge fluctuates between approx 0 & 1 volt, as the computer changes the mixture ratio. @ WOT, the voltage should be somewhat constant @ near 0.9 volts.
Tim
RedLeader289
May 28, 2019 01:47 PM
Giocio
Oct 1, 2015 12:20 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
90formulaVortec
Sep 8, 2015 12:42 AM
