Need 2 Know: Remote Start wire colors! PLEASE!
Old Mar 11, 2001 | 11:46 PM
kevin-design's Avatar
C'mon now! Surely I'm not the only person wiring a remote start system! This would be SO very helpful to post here- There are two wiring harnesses running down my steering column, 10 wires each (some same color). I NEED to figure out which to go to to make my remote start system work! I have everything else done, and my interior is ripped apart waiting for me to figure this out! Plz help me out here if you can! Somebody HAS to know this stuff! Thanks!
-Kevin
Old Mar 12, 2001 | 04:06 AM
Belker's Avatar
According to my info. (for a '91 Camaro):
Battery (+) = Red = Ignition switch harness
Ignition 1A = Pink = Ignition switch harness
Starter 1 = Yellow = Ignition switch harness
Accessory (+) = Orange = Ignition switch harness
Tach Sensor = at coil or Violet/White (-) "V6" at coil
Key Sensor = Light Green (-) = Ignition key warning switch
Neutral Safety = Orange/Black = at gear selector switch
Brake = White or Light Blue = at Brake switch
Speed sensor = Green = EMC, pass side dash, BLK24 Pin plug, Pin B11
Hopefully this info will help you make sense of something.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
