LOW VOLTAGE
Old Mar 12, 2001 | 12:39 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
LOW VOLTAGE
Ok, My car has been messing up for a while with voltage problems. I've gone through like 5 alternators and 4 or 5 batteries because for some reason the voltage in my car isn't staying up. I must have a short somewhere that keeps draining off the battery, but I'm not really sure how to look for it. Any ideas? Could it be in the wiring from the alternator to the battery? could it be from putting in the 350 and keeping all of the 305 parts? the voltage problem causes an annoying engine surge and the lack of charge also means a lack of power at lights, which sucks when your parked next to a mustang with your friend who owns a ford dealership sitting next to you...
Thanks, Mike
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch.
Old Mar 12, 2001 | 01:43 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I feel your pain bro.
I have gone through over 7 alternators and 2 batteries in the 5yrs I have owned mine.
the first think you always look for in this type of situation is bad grounds. look at all the wires that are grounded to the chassis and make sure they are clean and good. then start looking for shorts, starting from each ground. if you have any systems (lights radio ect) that behave in an erratic manor that would help with diagnosis.
good luck and well be here for help.
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax catback, urethane motor+trans mounts,
SSM SFCs, Bilsteins
very trick homemade ramair, Accel 300+ ignition system.
Planning: hedman 1-5/8 longtubes, NOS 150 plate, world 305 heads, replace the "peanut"! and other susp. mods.
check it out at:
http://www.geocities.com/transam617
327IROC85
Sep 23, 2015 12:11 AM
gta_knight
Sep 17, 2015 03:48 PM
ULTM8Z
Sep 16, 2015 09:15 AM
Formula_88AE
Sep 3, 2015 01:47 PM
RyanJB
Sep 2, 2015 01:27 PM
