Where is my chip located
Old Mar 12, 2001 | 10:41 PM
Stormshadow GTA's Avatar
i have an 87 gta 305 5spd i have an ads super chip and i wanna put it in where is my factory chip located.Can some tell me step by step.
Old Mar 12, 2001 | 11:10 PM
theformula's Avatar
Step by step here we go.
1 Open the passenger side door
2 lay on top of your passenger side seat and stick your legs outside of the car.
3. Now notice in front of you there is a lower plastic piece. (right under the "PERFORMANCE SUSPENSION) emblem you hopefully have )
4. Stick your head underneath and look up with a flashlight. You will see about 4 or 5 i think 7mm bolts.
5. Take a ratchet and remove each bolt placing them in a "dixie" paper cup as you remove them. (must be a dixie paper cup)
6. Now remove the plastic piece and put it in the back seat gently
7. Look up and you will see wires and dust. Look for a big metal box.
8. On my car (91 TPI), I have to remove two more 7mm bolts to free this metal box. On yours I don't think you have to.
9. Ok, pull metal box down, it may require you route it around some wires on the way down
10. Now the "metal box" aka ECU has 3 harnesses plugged into it. Press in on the tabs and pull out the plugs. Use some force
11. Bring the ECU inside to your kitchen table.
12. Grab a beer.
13. Take the ratchet and a 1/4" socket and remove the "access panel". It is only 2 bolts
14. Remove the access panel to see a "prom"
15. Do not spill beer inside the ECU.
16. Remove the prom. Don't quite remember how I did this one. Just monkey around . hehe
Now, if your ADS chip looks like your stock prom...you simply just install it in the same place. If it is a "piggy back", you have to connect your stock prom on to it...THEN install it.
You will know if it is a "piggy back" because it will have metal rods coming out of it.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5200rpm limit),Holley 9mm wires,Ac delco R43ts plugs,stock chip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited March 12, 2001).]
Old Mar 12, 2001 | 11:16 PM
theformula's Avatar
oh yea, look on the bottom of your access panel when it's off. If it has any "cork" type material on the underside of it you have to remove it. It could possibly damage the prom.
Deemax
Sep 12, 2015 06:53 PM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 6, 2015 02:35 PM
tonys91rs
Sep 2, 2015 07:07 PM
