Can I reverse wire a toggle switch? Want switch illuminated when switch is off...
Old Feb 16, 2001 | 01:41 PM
Baron's Avatar
I want to put a VSS override switch in my car, but I also don't want the light on all the time when I'm always driving...is there any way to wire this so the light is off when the switch is allowing power through and the light turns on when the power is off? Hence...when the speed limiter is overridden (VSS wire interrupted), the light is on...I really don't want the light on unless it's performing its specific function...it's pretty lame to turn off a switch to hit 120...any ideas?
'89 RS LO3- 140,000 miles
14x3 K&N Open Element
Ram Heavy Duty clutch
Edelbrock TES (Jet-hot coated)
Catco cat
Edelbrock 3" Cat-back
Pioneer DEH-P77
Dual .50 caliber machine guns just under ground effects
Coming:
KYB shocks
Edelbrock Strut Tower Brace
South Side Machine subframe connectors
When your buddy reaches for a 10-pound sledge and says "I think we're gonna have to modify the floor pan, okay?" the answer is NO.
Old Feb 16, 2001 | 04:21 PM
The ODB's Avatar
No problem. Just use a dual throw (5-prong) relay to control your VSS.
ODB
Old Feb 16, 2001 | 07:12 PM
Baron's Avatar
Sorry to be stupid, but what kind of part is that? Can I get it at Radio Shack? Would it be used in addition to the toggle switch or instead of it? Thanks for the reply...
Catco cat
Pioneer DEH-P77
Coming:
KYB shocks
Old Feb 16, 2001 | 10:02 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Radioshack has them. Run the soilnoid to the toggle and the 1st set of contacts use the Normally Closed (NC) to hook to the SES light wire; use the second set of NC contacts to hook to the VSS.
Old Feb 18, 2001 | 11:34 AM
The ODB's Avatar
A Single Pole Dual Throw SPDT relay.
Yes you use it with a toggle.
here is the explaination of relays.
http://www.the12volt.com/relays/relays.asp
Old Mar 14, 2001 | 06:55 PM
Baron's Avatar
Okay, went to Radio Shack, picked up a 12 volt SPDT relay...except it's for a computer. The "terminals" look like the ends of pins...will I have to solder this together? And if so, nothing is labeled...how do I know where all this junk hooks up? Thanks for all your help...
Old Mar 15, 2001 | 12:41 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The pins on a relay will either be labeled, or the package the relay came in will have the pin definitions indicated on it. The pin definitions for a SPDT (single pole double throw) relay are follows:
NC - normally closed contact
NO - normally open contact
pole - movable contact
coil - coil power wire
Note that some relays have an internal diode in parallel with the coil to shunt the reverse current spike generated when the coil field collapses. If this is the case, the coil is polarized and will be marked with "+" and "-" identifiers. If this is not the case, coil polarity does not matter.
Connect the VSS wires to the pole an NC relay contacts, and connect the lighted switch to power the coil. That way, when the coil is energized by the switch, the VSS circuit will be opened.
Tim
89GTAOz
May 16, 2020 09:31 AM
Street Lethal
Apr 30, 2019 12:14 PM
camaro11j
Sep 19, 2018 08:49 AM
Camarothatcould
Aug 20, 2015 08:49 AM
355sbcTPI
Aug 19, 2015 04:38 PM
