Code 16 won't go away.
Old Mar 18, 2001 | 05:33 PM
welld.geo's Avatar
Hopefully someone here at Thirdgen can help me with a wiring problem. I've got a '91 S-10 (I know, it's not even a car), but I can't get the code 16 to go away. I swapped in a 4.3 (W) out of a 95 astro, and graphed the new computer into my old harness. Every time the code sets, I get rough, almost lopey idle, with a nasty rich exhaust. When the code's not there, everything runs fine. Can anyone help me?
Old Mar 18, 2001 | 11:17 PM
RARE-ROC-Z's Avatar
sounds like a air sensor (MAF, MAP which ever it has). exhaust sensor. ( i cant think of the name, i am being dumb tonight). those regualte the engine so i would start there.
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 7.5" 10 Bolt 3.23gears
Bright Red Hardtop/ Grey Custom Interior
5,507 IROC's Coupes/Ttops; 2,415 5.7L IROC's Produced in 1990
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
Old Mar 19, 2001 | 06:17 PM
Vader's Avatar
Welld,
A '16' is a DIS (Distributorless Ignition System) fault. The 262 used coil packs and a crankshaft position sensor to time the ignition. Make sure the crankshaft position sensor is getting a good signal, is clean, and is adjusted to within 2mm of the reluctor.
Remember, your servicing a '95 engine and PCM now.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
BumpaD82
Feb 26, 2016 02:57 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
64Chief
Sep 12, 2015 08:05 AM
Fronzizzle
Sep 8, 2015 12:10 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
