Switched 12V wire to alt question...
Old Mar 21, 2001 | 02:29 PM
Biochem's Avatar
Car: 2002 SOM z28
So I have a switched wire comming from my harness (actually the same one that goes to the pos side of my choke) that goes through the 10W 150 Ohm resistor to the alt to "tell" it that the car is on and to charge the battery. I have to do this because I must have buggered up that wire (to the Choke light) when I re-did all my gauges a few weeks ago.
If that voltage is only about 11V, will that "tell" the alt not to charge as much (say 12.8V vs 14.4V)? Or is it simply a "Charge" or "no charge" deal and the speed that the alt is spinning (slower due to 25% underdrive crank pulley) is the reason I am not cranking out enough voltage?
If it is the fact that the wire should read 12V... how can I "up the voltage"? Add more/less resistance?
With my windshield wipers going, my headlights on, and only the vent running, my battery (only 4 months old) is drained after only a few minutes in slow traffic. It wouldn't turn over last night, but this morning did, and after I drove a few blocks, the blinkers started to blink their normal speed and the car perked up again.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Mar 21, 2001 | 08:25 PM
ZANG's Avatar
I HAD A SIMILER PROBLEM ON MY OLD CADDY. TURNED OUT TO BE THE BELT WAS SLIPPING. USUALLY THEY MAKE NOISE BUT THIS ONE DIDN'T.
89GTAOz
May 16, 2020 09:31 AM
Jae992
Aug 27, 2015 09:07 AM
Dialed_In
Aug 20, 2015 01:45 PM
355sbcTPI
Aug 19, 2015 04:38 PM
apie2546
Aug 8, 2015 07:12 AM
