ignition system for carb swap
Old Apr 2, 2001 | 06:39 PM
NitroMac's Avatar
im looking to swap my ccc for a holley and am being told by everybody that i also need to switch distributors. why is this? and can i make my old on work for a little while?
Old Apr 4, 2001 | 01:14 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
What's a ccc?
Tim
Old Apr 4, 2001 | 05:24 PM
Cosmik Debris's Avatar
Computer Controlled Carb??????????
Cosmik Debris
Old Apr 4, 2001 | 08:49 PM
cfabe's Avatar
Yes, everyone is right, you do need to install a different disttributor. On your current setup, the ECM controls the spark advance. If you run the holley with the current dist. you will get 0 advance. This will result in pitiful power. You will be able to start the engine with your current dist in there, but you really want to install a vacuum advance carb. You can use an older stock vacuum advance HEI carb. It will have a vacuum diaphragm cansiter on the passengar's side. This should be hooked up to ported vacuum from the holley.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
gta90
Sep 15, 2015 04:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
